Leaking Shower Valve
View the thread, titled "Leaking Shower Valve" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
I have a leak coming from the bath/shower/off switch on the attached shower valve.
The leak is coming from what looks like a rubber washer behind a brass retaining clip.
I've not removed the retaining clip as if I make the leak worse I won't be able to switch the water back on.
Any ideas with this one? Is it likely simply a new rubber washer, new cartridge?
Apologies, I don't know the model of the shower, although it is about 15 years old.
That is the flow cartridge. It is likely to be a ceramic disc mechanism, could be grit caught between the discs so it never shuts off properly- this is then leaking up the gland.
I would remove the cartridge, photograph measure and look for identifying numbers.
Then reassemble greasing up or replacing any o-rings in the spindle. Then try to find a replacement cartridge using what you found in removal.
Reply to the thread, titled "Leaking Shower Valve" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
MrGatch,
Ben-gee,
