View the thread, titled "Leaking Shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
J
Juggy001
I have a three way shower valve which is thermostatically controlled. There is one control to change the temperature, one control to select one of the three outputs and an one off control. I have replaced the thermostatic cartridge as I was told. The vendor said that this could be a cause of the leak but it is not. The leak is linked to the on off control. When I apply pressure to the on off control and push it in, the leaking stops. The on off control does not seem to be a cartridge but is fused into the shower valve itself.
is there any part available or anything that I can do to sort out the on off control and stop the leak? Any ideas greatly appreciated!
You know the manufacturer as you have replaced the cartridge so give them a call and ask their tech department, you should be able to change it though.
Reply to the thread, titled "Leaking Shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
