I have a problem with an old stopcock (40 years?) fitted on the old alkathene supply pipe. This is in a property owned by an elderly friend and the stopcock has been leaking from the spindle for many months. Despite several attempts to pack out the gland with PTFE the valve continues to leak. My preferred option would be to replace the stopcock altogether but was discouraged from this by a couple of local plumbers in the nearby merchants who believe alkathene – I have not come across this stuff previously as it seems not to be used in London - is a difficult material to work with and I would be better to try to get the stopcock apart and replace as many parts as possible from the merchants.
Despite my best efforts using a set of footprints and an adjustable spanner I cannot get any movement on the upper part of the valve as there is limited room for movement under the kitchen sink. So for the moment I have left the valve with a few squirts of WD40 (OK, a bit desparate) around the fibre washer with a view to returning tomorrow.
If further efforts to dismantle the stopcock prove futile then I will require to replace the thing, whatever, despite the other plumbers’ misgivings. I am unable to give a true specification of the alkathene suffice to say that its diameter is 28mm. I originally purchased a 28mm stopcock for copper pipe with reducing set for the 22mm copper side though the guy behind the counter in the merchants is uncertain as to whether this should be used here. So I think it might be best to buy one of those Plasson or Philmac valves that come with varying sized adaptors (universal couplings?) and hope this can be made to fit. I can find no sign of any coloured printing on the pipe itself but from the table below the nearest I guess it may be ¾” class C.
I would have thought that this type of pipe would come with inserts but the one of the guys in the pm’s does not think this is the case. Surprised to hear this, though.
Suggestions from anyone who has experienced the joys of alkathene would be much appreciated. 😉
ID markings on the pipe blue writing for class D or green writing for class C.
Approximate Alkathene Pipe Sizes | ||||
Pipe | Class C ID | Class C OD | Class D ID | Class D OD |
3/8 inch | 12mm | 17.5mm | 17.5mm | |
1/2 inch | 15.5mm | 21.5mm | 14.1mm | 21.5mm |
3/4 inch | 19.5mm | 26.9mm | 17.5mm | 26.9mm |
1 inch | 24.5mm | 33.7mm | 21.9mm | 33.7mm |
