View the thread, titled "leaking washing machine tap" which is posted in UK Plumbers Forums on UK Plumbers Forums.
spider12
Ive tried various ammonts of PTFE tape(3,4,5 turns)but wont stop leaking.What amI doing wrong?
Take the ptfe tape off and swap the washer , failing that just get a new hose.
The washing machine tap is a threaded fitting with an isolation lever no olives it just screws in, Whats confusing about it?
thats what i thought. whats confusing about it?.
which end is passing, hose side or pipe side?.
pipe side. Ive tried numerous turns of ptfe tape, should I try boss white compound?
are you saying, there is a nut on it but no olive inside, or its a female union?.
then 3-4 wraps of ptfe does nothing.
wrap anticlockwise 14-16 wraps on up and down the thread if its descent tape then crank it on.
sorted.
sorted.
many thanks, wasnt using enough tape about 10 turns did it
Hey
As you say that the tap is threaded fitting, i think there may be a hole in a pipe nearby the tap then i suggest you to use m-seal at leaking place.
Regards
Olivia
Sewer Line Cleaning
i think id go with cutting it off and fitting a new one for peice of mind more than anything
Reply to the thread, titled "leaking washing machine tap" which is posted in UK Plumbers Forums on Plumbers Forums.
