Got called to a dripping compression, hard to get to as under sink in corner.
Anyway, tried to tighten but kept leaking, drip then weep.
Thought why?? Undid the nut & it was all wobbly like the pipe was hanging off. Then had a eureka moment, it was a tap connector!!!! I bunged a fibre washer in & loctite on thread & tightened it up. Hey presto all ok.
Here's a pic, yes I snipped the loctite thread hanging.
Just interested to make sure I understand this correctly.
The 90 Deg elbow is a standard compression elbow, but Tee on the bottom of the left hand pipe actually has a tap connector soldered into it. The nut on that part is part of the original tap connector and the prep on the end of the pipe would be with a raised upset creating a flat for a flat washer to sit on. Then someone has discarded the original nut and olive on that half of the elbow and stuffed the tap connector into the elbow ??
Or have I completely misunderstood.
Martin
