Linking up boilers.
View the thread, titled "Linking up boilers." which is posted in Boiler Advice Forum on UK Plumbers Forums.
V
Vincent2012
How to link a multi fuel boiler with oil fired boiler in a bungalow? Any advice?
Also can be done with twincoil copper cylinder & check valves on pumped pipes to rads. Or can be done using a neutraliser. All methods have good & bad points I guess!
[DLMURL="http://www.dunsleyheat.co.uk/linkupsys.htm"]dunsleyheat uk manufacturers of multifuel stoves, range cookers, boilers...[/DLMURL]
As Best says, one of these does it but does involve a fair bit of wiring, additional thermostats and 2 x pumps!
Reply to the thread, titled "Linking up boilers." which is posted in Boiler Advice Forum on Plumbers Forums.
Vincent2012,
thereisawizza,
