View the thread, titled "Loads of air in central heating." which is posted in Central Heating Forum on UK Plumbers Forums.
After bleeding it earlier this evening, it was on for a few hours being very slow to get warm.
After turning it off it was refilling for at least 15 minutes until I turned the valve off.
No signs of condensation.
There’s still air moving around quite loudly 20 minutes after turning heating off.
All downstairs pipes are buried in the concrete floor.
Worrying.
If you look near the roofline outside you will see the ‘overflow’ pipe coming from the f&e tank for the ch. when the heating is on tomorrow look to see if any water is coming through that pipe. If it was ‘pumping over’ water coming out of that pipe could confirm it. If not and you are still losing water then that water has to be going somewhere else ie a (likely) leak in downstairs underfloir pipework.
Worrying.
With the amount of water you are losing I would expect a carpet to be wet if a pipe within the concrete floor had failed.
I’ve remembered:
Only thing I did was fit two Z-Wave thermostats (just changed the plastic part of the TRV, didn’t change the actual metal valve), at the beginning of December.
And a few months back I put the CH pump from speed 1 to speed 3.
I changed the pump years ago, at the time I didn't realise it had different speeds. I was trying to improve flow as three radiators are always a bit slow to warm up, they are on the same leg.
I held a bowl over the flue for maybe 30 seconds this afternoon, and this is what was in the bowl.
https://i.*********/PwP5IfZ.jpg
https://i.*********/uYVNOtG.jpg
Undertandable but you can improve heat up time for slow rads by ‘balancing’ them. Has reducing the pump speed affected water liss from the system?
Reply to the thread, titled "Loads of air in central heating." which is posted in Central Heating Forum on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Chris12345678,
John.g,
