USA Looking for correct size tool, box spanner or similar
View the thread, titled "Looking for correct size tool, box spanner or similar" which is posted in Plumbing Tools on UK Plumbers Forums.
Would like a box spanner or similar to help tighten the locking nuts on a replacement sink tap ( has one vertical lock nut over a central cylinder plus for a click clack waste locking nut.
I realise these aren't meant to be hardened down, just saves my fingers and will allow me to nip it up firmly.
I have researched and found mention of BSP thread sizes, but not the size across flats of the lock screws
Also, I see on American sits a tool to prevent the sink plug rotating, when tightening the lock nut....using plumbers mait
thanks
Hello and welcome! If you own, or can borrow a socket set you could try to see which size socket is perfect fit, so to know what spanner needed. A standard deep socket will often do for some taps. There are box spanner sets available for taps from Europe usually about 3 double ended (6 sizes) box spanners in metric. Rothenberger is one set, if that's what you need, but if you are in USA your taps might be totally different and perhaps even good old imperial nut size
As Best says, I simply use deep 1/2" drive sockets. I have a selection and have never failed to be able to use them having changed 1000s of taps.
Reply to the thread, titled "Looking for correct size tool, box spanner or similar" which is posted in Plumbing Tools on Plumbers Forums.
Disaster Area,
Welder,
