DSInstrell
I have a problem with a loose basin mixer tap. It's a single screw fixing and, unfortunately, the metal horseshoe washer has become bent.
1) Is it possible to get a replacement horseshoe washer? I've tried a couple of local plumber's merchants who don't have any spares.
2) Is there anything available that will centrally locate the tap prior to tightening to prevent movement?
3) I've been told that, as a last resort, it would be possible to use a high-quality sealant to bed down and fix the tap in position prior to tightening. If this is correct, does anybody have any suggestions as to what kind of sealant I need?
Any advice would be most welcome. Thanks in advance.
