View the thread, titled "low hot water pressure from combination tank" which is posted in Bathroom Advice on UK Plumbers Forums.
C
captain beep
Hi, I couldn't find the answer to this in faqs so I hope someone can help.
I recently turned off the inflow to a friends combination tank and forgot to turn it back on.
The tank has been largely used without realising it wasn't refilling and, even though I've turned the cold water flow back on, the water flow from the hot taps is very low.
The make is Manco if it makes any difference.
Thanks in advance,
Captain Beep
conect washing macine taps together with the w/macine hose blast thew cold up the hot be aware the tank could over flow that should sort it
Reply to the thread, titled "low hot water pressure from combination tank" which is posted in Bathroom Advice on Plumbers Forums.
