View the thread, titled "Macerator / saniflow query" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi all, hopefully someone will be able to help me with this question. I have already done a lot of digging around this site and others and not found an answer....
Yes a macerator pump is needed (absolutely no room to get a normal waste pipe back to the soil pipe) I appreciate all the associated issues with them... We have not decided on a specific model yet, or indeed whether it is possible at all.
I will be putting the toilet on the ground floor, and just 3m horizontally from the soil pipe. Ideally i would like the pump to push the waste down (12 inches to below floor / joist level), then horizontally 3m (at the recommended 1%) to join the top of a horizontal run of our soil pipe. - QUESTION - will the pump cope with the initial drop to below floor level? or will i need a small amount of vertical inside the cavity to allow for back pressure to the pump, then once past the check valve the drop and then horizontal run?
Or .... Option 2 is to pump up and into the ceiling (2m), but this will require drilling through 3/4 joists before i can get a straight run to the vertical soil stack (3m). which i know is not ideal either and will require jointing lots of pipe.
Any thoughts team ??
Thank you
Paul
Or .. Option 2 is to pump up and into the ceiling (2m), but this will require drilling through 3/4 joists before i can get a straight run to the vertical soil stack (3m). which i know is not ideal either and will require jointing lots of pipe.
Thank you
Paul
Put up a plan drawing of the layout and then an elevation with the relative heights marked. This way you will get some advice. Centralheatking
Reply to the thread, titled "Macerator / saniflow query" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread starter
Joined
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
None
Cpaulc,
rpm,
