View the thread, titled "Main 24HE combi boiler problem" which is posted in Boiler Advice Forum on UK Plumbers Forums.
O
omen911
Hi, I wonder if you can help? My Main 24HE combi boiler has over the last few months been shutting off in strong winds. The boiler is in the loft on the gable that faces the prevailing wind. It has been serviced and the Air pressure switch changed. The flue does not appear obstructed and I am wondering whether the fan could be weak although the heating engineer said it sounded ok when he listened. I have looked through the burner window when the fault occurs and the flame is cut dead so I think the AP switch is working OK. Is the fan a known fault and can it be tested? I have tried the rather unscientific test of feeling the strength of the exhaust and it seems less powerful than my neighbour's but I realise this is an unreliable experiment. I don't want to replace the fan without good reason. Thank you.
you dont want to be replacing the fan at all, get someone in who knows what they are about.
You need a gsr in to look at your boiler. We cannot and will not give advice on the installation or repair of boilers for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a pm to either Gas man or Redsaw who will then check you and then give you access to the gsr private forum.
Thank you.
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to the thread, titled "Main 24HE combi boiler problem" which is posted in Boiler Advice Forum on Plumbers Forums.
