View the thread, titled "Main Combi Eco - No CH, DHW working fine." which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
F
FlowGas
Hi everyone, my next predicament. I've got a Main Combi ECO 25 - no CH, DHW works fine.
I've just replaced the Motor valve - no luck!
Next the whole 3-way Diverter valve? Is not that then what else?
There is no room stat attached.
Any advice is much appreciated.
time clock? has to be electrical,have you looped it,if so and motor changed pcb is the only bit in between
Yep, it's in an Out house - turned on when required via the heating and hot water controls.
If the controls are seperate, which i imagine they would be, and in the house? Best thing to do would be put a link in between the 2 external control wires in the boiler, they are next to the mains in on the connector block. Im sure it is labeled inside the boiler
Reply to the thread, titled "Main Combi Eco - No CH, DHW working fine." which is posted in Gaining Plumbing Experience on Electricians Forums.
