View the thread, titled "Main combi hot water" which is posted in Bathroom Advice on UK Plumbers Forums.
M
marsaday
i have a main combi and the hot water is going hot then cold and is now more cold than hot.
Is this a diverter valve problem ?
doing the plate heat exchanger tomorrow and then check the diverter valve.
Do i need a whole divert valve if this is broken or do you just need the diaprahm
HE changed today and all okish. the water works fine. when the heating comes on the hot water gets to 60C. Plumber said once central heating gets warmer,say in an hour, hot water will be fine.
So we are going to see how it gets on and if any more problems will change the diverter.
Reply to the thread, titled "Main combi hot water" which is posted in Bathroom Advice on Plumbers Forums.
