View the thread, titled "Main water valve, cannot find it" which is posted in Bathroom Advice on UK Plumbers Forums.
Hi there,
I have just bought a flat in an old tenement building in Edinburgh. I was trying to close the cold and hot water for the tap in the kitchen so i searched underneath the sink, but there are no valves attached to the two pipes that go in the tap. I have followed the pipes and they go through a wall in the storage room (I guess it was the place where the old water tank was stored) and then the pipes go underneath the floor. In the same storage room there is a hole in the floor with the thing in the pitures. Is that the main valve for the water supply? I have tried to turn clockwise but it is stuck, is there a way to turn it off? Another question is, how do i turn off the hot water? i cannot find any valve for it.
thank you so much.
I wouldn’t rule it out, I have seen them in new build care home with an access panel by front door which is where the main stopcock is located.
Thank you CBW1982 and to everybody. I have found a valve outside the front door. I didn't try yet, but I think it is likely to be the main water valve. It is in between gas pipes.
Hi Sarah
First of all don't touch the plug cock under the floor. It is the old scour cock (=drain cock) for the hot water cylinder. It allows the water in the cylinder to flow away into the drain. If your cylinder is still in place and you open that, you will be unable to heat the water as the cold tank will constantly be running into it. If the cylinder has been replaced as you seem to be saying there is a risk that the lead pipe has not been blanked off and you could leak on the neighbours below. It has nothing to do with the main supply.
Your main water stopcock will originally have been at high level where the mains water from the lead riser ran into the cold water tank. If you are in a top flat it could have been in the roofspace, otherwise most likely above the bathroom.
If you still have a cold water tank that is the place to look (the lead riser ran up the building and each flat had a branch at high level, you will only have a branch lower down if you are a top flat and the riser has been altered, or if the high level branch has been run downwards to supply taps). As you rightly say, a stopcock on the riser would turn off any flats above you, so that has never been normal practice. The stopcock which does turn off the whole tenement is under the road, called a Toby cock.
I don't know whether you have some reason for not contacting an Edinburgh plumber but that's who you need, not Scottish Water.
Most of us give free estimates and would locate the stopcock for you in the course of the examination.
Reply to the thread, titled "Main water valve, cannot find it" which is posted in Bathroom Advice on Plumbers Forums.
