View the thread, titled "Making a diy decarbonizing heater for my bbq gear??" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
mutley racers
Subscribed
So just a thought, do you think it is possible to use a 40ltr garden waste bin by just putting an immersion heater in the lid and just put a plug on the cable and plug it into a socket for in my garage? Maybe set it to 50degrees? Am pretty sure the plastic would not melt at this temperature.
What do you reckon?
If so, can you buy a female tank connector this side?
I hate scrubbing bbq stuff!!!
Or maybe use a stainless steel bin?
Ideas would be great
What's the power rating of the immersion heater? Immersion heaters are usually on their own circuit due to high current requirement - not just plugged in to a socket. I hate to think what regulations you would be breaking?!
See if you can get hold of an old Burco wash boiler. Would do exactly what you want. Alternatively look for a home brew boiler, I used to have one called a Brew heat boiler.
Really? A bit Heath Robinson and not something you'd do for a customer / professionally but it doesn't sound too bad to me. A single element will normally be around 3KW so will run fine off a domestic socket.
What's the worst that could happen assuming you put it on a concrete garage floor?
1) Element oversized: plug fuse blows
2) Both element stats fail and the water exceeds tank melting point: wet garage, knackered element.
If you had a galv tank you could adapt then, as long as you x-bond the earthing properly, even better!
thanks guys, the home brewing kit is pretty much the same idea. And that is plastic they use too. My garage is on its onw circuit from consumer unit with rcd. So, do you think i can just put a plug on and plug it in? If so, where will i get a tank connector for immersion heat thread?
Garage is also a concrete floor. So to be honest. like you say wheeto, whats the risks?
Why not wait until you rip a cylinder out and cut the top off it?
Immersion will be ok on a plug top just about, just make sure you use the correct size cable.
Seems an expensive way to wash the dishes though!
Risks:
1) Open tank of hot water
2) Immersion heater in a plastic container
3) Immersion heater not correctly wired i.e. on its own circuit
What you do in your own garage is up to you, until someone else gets hurt. If you know the risks and want to tinker then carry on🙂
Like Wheeto, i don't see any real problem with it but i wouldn't use a plastic bucket. Best ideal would be wait till you remove a hw cylinder with a side entry and cut the top off at whatever height you like. Dress the edge of the cut off top so it fits over the lower part, a bent male and a bit pipe for a handle. An insulated cylinder will keep the costs down a bit. You better put a bit tape over the cut edges or better fold a welt to stop it cutting you.
Std immersion elements are 3kw (13 amp @ 230v). The same as a lot of electric heaters so no big problem plugging it in. If it is a 2kw element it will draw under 9 amp.
A bit of commen sense and latteral thinking, no probs!! second hand cylinder probably the easiest / best option though, could you cut the coil out from the inside and cap off the tappings!!
just had another thought!!! if you get an indirect with a bottom entry immersion, cut off the top, cap off the coil tappings and cut most of the coil leaving the lowest most part coil in place, thus giving you a kinda shelf to rest the bbq rack on without it touching the immersion.
Any cylinder would do. A coil is easily blanked off using 2 x 1" brass plugs and jamb nuts and you can solder an immersion into the side with a bit grade D wiped around it. Or as ^^
thanks guys. I have a 48inch top entry in the garage. When i took the immersion out after applying heat, i ripped the copper out and not the thread. Sorry tamz if i seem daft, but would do you mean fold it in half? Adm, like the idea of leaving part of the coil for a shelf
Reply to the thread, titled "Making a diy decarbonizing heater for my bbq gear??" which is posted in DIY Plumbing Advice on Plumbers Forums.
Thread starter
mutley racers
Subscribed
Joined
Location
Hampton court, Surrey
Thread Information
Title
Prefix
N/A
Forum
DIY Plumbing Advice
Start date
Last reply date
Unsolved
Thread Tags
Tags Tags
heater
mutley racers,
zzzjim,
