stan1
Hello.... hope someone can help or offer advice.... I am about to buy an underfloor heating manifold converted to work with rads....so that means the flow meters taken off and the the manifold capped to close of the connection points that were used by the flow meters,,, my enquiry is to ask if it is ok to add the hot cylinder to the manifold..on one of the points of the manifold..so instead of getting a 10 way manifold ..I would buy an 11 way manifold to control the hot water cylinder as a separate item while also having control of every separate rad.....I will eventually replace the manual valves on the manifold with motorised valves so as to control the on / off times of each rad and if its ok ...of the hot water cylinder... this will allow me have hot water without the need of any rads running.....for example in the summer time.... so is it ok to add the hot water cylinder to this manifold in this way...Thanks if you can help.......Billyie
