View the thread, titled "Maximum deviation from horizontal before air lock?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
In a pumped radiator circuit, in long horizontal-ish stretches of pipework (say 15mm dia), what's the maximum typical rise/fall before air pockets become persistent (aren't moved on by pumped flow) and cause noise/gurgling, and before air locks prevent flow?
Apologies if this is a common query, but I've not figured out how to phrase the question such that I can get an answer via Google.
I'm expecting that it's something like >3-9cm for air pockets to persist, and >10-30cm for air locks to occur.
I appreciate it can depend upon the pump...
I'm considering the use of soft copper pipe, manually unwound from coils, which can end up being a bit wiggly, and moreover, I can't be sure the successive floors it'll be going along are all exactly the same height (and this is without intervening radiators to capture stray air).
Reply to the thread, titled "Maximum deviation from horizontal before air lock?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
