View the thread, titled "Minds baffled by a shower on a quote" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
T
tommy1712
Evening lads, just got to look at a quote for a shower system not working properly,
hear goes
pupm was was replaced by someone else, the cold is fed correct from the tank (all be it in 15)
the hot is juts teed from the dhw feed.
The shower runs constantly cold but the cold supply pipes are hot so it is pumping hot when I shut the cold supply off the shower runs hot! I ballanced the cold so it was a usable temperature but the mixer would not adjust just stayed a constant temp.
Pump also over runs for 15-20 seconds after shower shut off.
I am am convinced the mixer has had it and the over run is caused by the incorrect installation.
any other ideas to throw in the mix? I recommend just ripping it all out and installing new corretly but that not gunna be cheep
so gunna start with replacement mixer and see how that goes
Banter all day long narkey or digging out is a different thing and to be honest.
All I wanted to see if anyone else had any ideas on what could be the issue if I had over looked something stupid! Not to be dug out over my spelling I am a plumber not a rocket scientist!!! Especially where there reviews ain't all that lol but I am not that pathetic and there is always another side or a reason
we have all said our piece now lets move on 🙂
personally I would get a copy of the pump installation instructions and ensure it has been fitted iaw the manufacturers guidelines ie in 22mm feeds if required etc etc, then check the mixer filters and check vlaves before bothering to rip out and replace anything.
Hey tommy I wasn't insulting you I actually thought a customer had emailed you that hence my first post wasn't having a go at you surely you can work that out 🙁
Would explain the pump running after shut off, it's not a negative head pump (don't shoot the messenger just asking) :wink:
That was my first thought. Is it a neg head pump?
Does the pump supply only the shower?
If its a bar mixer whip it off check flow through pipe stems could be pump inlet filters blocked on one side still needs repiping with dedicated hot feed 22mm cold supplys with hot feed cistern outlet raised above cistern outlet height for dedicated cold to pump make sure cold cistern feed is tsken from the non fill valve side of the cistern all the usual Pump Mi stuff that always seems to be ignored whenever you get called to a none working or problematic shower pump.
Op I think your judgment is sound and its likely the thermo mixer cartridge that has had it.
The mixer is behind the tiles, I did say that the filters could potentially blocked, but then it still had a good ish flow rate, that still doesn't explain the over run tho. I think the whole this needs binning and re doing, it was like mario had been at it
Firstly
Disconnect the pump outlets (iso valves should be on the inlets) connect two lengths of hose to the outlets and stick em in the bath. Open the isos and flick the pump on. Observe the temp of the hot water out of the hose. If this is fine then it is the mixer.
Secondly
Even concealed mixers can usually be dismantled from the front. Posting a pic would help to determine this for you.
The cold feed being in 15mm shouldn't make a whole load of difference unless it's 3-4m in length going sideways etc, a lot of shower pumps under 2bar are 15mm connections. I personally still feed them in 22mm though reducing at the pump. Teeing into the hot water drawoff is also ok if it's below the vent take off or teed downwards. I still use a s flange though. Is the pump below or above the hwsc? If above has it got an anti gravity loop? This can cause issues if not.
No isolators just a couple gate valves on the inlet side.
I think is gunna have to pop round tonight and basically tell her it's a complete new installation or I am not interested. the whole set up is a mess if I try to just fix one part it's still a crap installation and bound to still not work 100% and be nothing but a pain in my backside
my grandma is bad aswell as being deeselectrik!.
dos the hat coming out the hat side, cole out of cole? isolate cole and trie thot!!
ad it befor were sum1 swaped em over an didnt wurk rightly.
Reply to the thread, titled "Minds baffled by a shower on a quote" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Unsolved
tommy1712,
REDSAW,
