J
jmarsden0
Hi
I have a Powermax 155x situated in the middle of my flat which has a boiler flue running the width of the flat (5m) to an outside wall. The flue runs along the ceiling void, and is concealed.
The void is only 96mm in height, I understand that they are usually much taller. One contractor has refused to fit inspection hatches because there won't be enough space to properly inspect/replace the flue if they had to - so the hatches won't meet regulations. Another contractor says that as long as hatches are fitted every 1m then it's fine.
Could anyone tell me if I am breaching reg's by fitting hatches every 1m with a void of just 96mm? As not all parts of the flue are available to buy, I cannot move the Powermax to an outside wall or lower the existing flue in order to create more void. If I cannot fit hatches I need to install a new boiler/flue,etc :censored:
Cheers,
James
Cheers,
James
