View the thread, titled "Mira Power Shower Pump squeek - anyting to be done?" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
pauljs
Hi everyone,
I have a Mira Enduro "Universal" 1.5 bar double ended pump. the wife turned on the shower this morning and nothing happened (she had a shower with no power).
I am tasked with troubleshooting and have read the appropriate guide.
When I tried the shower it worked fine a little later on
  • I left it running on C 5 mins H+C 5 mins H 5 mins and then stopped restarted it a few times - worked each time
  • I used a magnet to test the reed switch on each side and they are both working (now at least).
  • It then failed to turn on once for me but its now fine again.
I have noticed a startup and shutdown squeek and the recording is available but the forum will not let me post it. I will try to post it in a reply to this.
Can anyone tell me if the noise is normal for a 4 year old pump and if not what the troubleshooting steps might be? Also I am not sure if the noise is related to the intermittent failure to start but it does seem likely.
Many thanks
Paul
Reply to the thread, titled "Mira Power Shower Pump squeek - anyting to be done?" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
