Guest viewing is limited
Mira Select EV
View the thread, titled "Mira Select EV" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I am DIY but I am competent. I have just fitted a Mira Select replacing a Mira CombiFlow which I fitted 10 years back. The Select is dripping from the shower head (3 drips every 30 seconds). I have to admit that when I fitted it a did not fit the flow regulator (because I didn't know where to put it). Could that be why it's dripping / why the off control is allowing water to seep through?
Thanks in advance
I am in the UK (Liverpool)
I called Mira, they asked what my pressure was and was it within the spec (spec below). How the hell do I know what bar my water pressure is? I called United Utilties and they don't know but said it was unlikely that I was more than 5 bar.
Is there any way I can find out what my water pressure is without buying some kit?
Pressures
• Max Static Pressure: 10 Bar.
• Max Maintained Pressure: 5 Bar.
Reply to the thread, titled "Mira Select EV" which is posted in UK Plumbers Forums on Plumbers Forums.
Pensioner75,
Ben-gee,
