Mira shower mixer adjustment.
View the thread, titled "Mira shower mixer adjustment." which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT.
THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE.
THANKS
There is a temperature adjustment screw in the centre of the cartridge, I think it’s a little Allen key.
I would try this first before replacing the cartridge as often it is all that’s required.
Look up the instructions online for your particular model.
Thanks Ben. You are quite right. Found the instructions on line so good to go!
Topic closed, thank you all.
Reply to the thread, titled "Mira shower mixer adjustment." which is posted in Showers and Wetrooms Advice on Plumbers Forums.
cheddarman,
cheddarman,
