G
Guest123
Can't you tee off and reroute it to The House of Commons?i ran a gas supply to an orphanage using speedfit
I've actually made loads of mistakes and even repeated some (especially the pouring the waste trap contents down the sink/basin I've just taken it from), but the most expensive mistake was buying a "Plumblocal" franchise in 2004
you lot have jinxed me,me the old man and the captain were on a boiler swap and 10 rad fit today,the old man not thinking cracked on and hung a rad because the captain cant keep up,he grabbed the sds because they are hard walls and drilled strait through the wall killing the designer paper the other side
i had a boy with me do that luckily we managed to swop the rads back to back same size and fixed the brackets with studding and nuts ive always wondered if some smart bum decorater ever took the nuts of one side to have the other rad fall ofyou lot have jinxed me,me the old man and the captain were on a boiler swap and 10 rad fit today,the old man not thinking cracked on and hung a rad because the captain cant keep up,he grabbed the sds because they are hard walls and drilled strait through the wall killing the designer paper the other side
I was doing some pipework alteration on a central heating system , couldn't solder so using compression fittings.
Only hand tightened a couple as I fitted the pipework together, all in place correctly and I tightened up before refilling the combi - only I'd missed a joint on the drop within the wall!!!
Luckily I had it all dried up before the customer got home!
Reply to the thread, titled "Misstakes...?" which is posted in UK Plumbers Forums on Plumbers Forums.
