View the thread, titled "Mixer tap connection" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi
I have a old mixer tap in my kitchen not sure what brand and it has solid copper connections going to it the threaded brass soldered end going into tap. Unfortunately there is a pinhole on the collar of the brass connection so i need to fix it or replace it with flexible tails. But the tap has a odd sized thread its not metric or imperial so what would it be ?BSP ? its about 12mm in diameter, ideas could i retap the thread on tap to metric or get a adaptor to go to metric flexible tail
thanks
Have you removed the tap?
Just take it to the merchants and try what they have- I suspect it’s 12mm (what makes you think it isn’t? - have you tried this already?)
If it’s for the uk market it will be 8, 10 or 12 mm.
Failing that - mend the pin hole with solder.
I have tried m12 bolt in hole in tap and it does not fit. I would rather replace with flex hoses as haven't got blowtorch to solder hole
Reply to the thread, titled "Mixer tap connection" which is posted in UK Plumbers Forums on Electricians Forums.
