Monobloc tap hose connections
View the thread, titled "Monobloc tap hose connections" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Evening chaps.
I've got a Bristan monobloc mixer to fit. Now, the 10mm ends of the hoses fit a few inches deep inside the body of the tap, so can't get a spanner on them. Can't use a box spanner as even if I could get one on the hose, I wouldn't get it off as the other end is 1/2" bsp!
What do I do now? :rolleyes2:
Cheers.
This design of tap is very regular these days , pathetic design , as shaun says hand tight but I still need to check with a spanner
Use a smear of lsx on the o rings and make sure you don't kink the hoses when you twist them.
Love bristan monobloc taps
Seen a few of the Monobloc hoses in the past with the O rings all cracked just out of the box. Doesn't give me much confidence in them, although haven't seen it lately.
And why do some mixers come with spare flexi hose O rings in a wee bag? What's that about?
Yeah I've often wondered about those! More likely that the hose will split than the o-rings wear out. Maybe they're in case people over tighten them and tear the o rings??
You could be right. I wondered had the O rings already supplied on the flexis have been perished on some, like I used to notice and they supplied spares just to be careful.
I wish the manufacturers would leave instructions to explain the purpose of all the bits supplied in the box to help make it easy for stupid people like me! :smile:
Something you can ask the reps when you get behind the counter shortly in your new job. :smile:
Reply to the thread, titled "Monobloc tap hose connections" which is posted in UK Plumbers Forums on Plumbers Forums.
HawkWhiteFinger,
Subby,
