Moving Earthenware Waste in Concrete
View the thread, titled "Moving Earthenware Waste in Concrete" which is posted in UK Plumbers Forums on UK Plumbers Forums.
B
blawford
So judging by the other thread I started I'm going to struggle to connect a new toilet with my waste pipe hole being so far from the wall (about 30-35cm to be precise). I am therefore thinking about the logistics of moving the opening.
As the title suggests, it is a ceramic/clay/earthenware (not sure what the right term is) in a concrete floor. The tools I have at my immediate disposal are a angle grinder with diamond blade, a few chisels and hammers, drills (non SDS) and masonry bits.
I assume the aim is to get access to the pipe, cut it off clean and then fit a 'Flexible Pipe Coupling' (can't post a URL) to attach a new PVC pipe to?
Few questions, how delicate is the pipe and how do I go about this job without breaking it? Can I do this job with the tools I currently have available or should I be buying/hiring something? How long is this job likely to take me roughly?
Thanks.
You will have to work from a few inches either side of the waste pipe and carefully work your way in to the pipe's outer surface, like an archeaologist uncovering something delicate. I have used an SDS hammer drill with a chisel, a spike and a chasing bit as needed.
It's nerve wracking stuff but if you are careful it can be done. I have found that the concrete usually flakes off cleanly from the pipe's surface as you get near.
Then you are going to need the make enough room around the pipe so you can grind the pipe away bit by bit until you have a square face you can get a connector on to.
Thanks for the reply.
How long would you estimate it might take? What do you do afterwards, concrete it back in?
Very difficult job to do for someone who hasn't done it before.
You may want to find out how thick the concrete is. Drill a hole until you break through.
Measure how far under the floor level to the bend, you may be able to determine which way the pipe runs from the bend.
I would start at the point where the waste for the ne pan has to be and work my way back to the existing pipe location.
It could be very tricky depending on the thickness of the concrete, depth of the horizontal drain and direction the drain is running.
How long will it take - you will know when you're finished, and yes, concrete it back in
Such a spoil sport! 🙂
Did as you suggested, drilled a hole with my 18V drill driver, went though OK but the drill wasn't really powerful enough to go very deep so started chiseling. Concrete wasn't very thick but I did come across brick a bit further down. Managed to make a 7" hole in about 30 minutes or so.
I am assuming I can't do any structural damage doing what I am doing?
The soil pipe is currently a sweeping 90 degree bend away from the hole I have made, I am also assuming that I need to cut it off before the curve 'downstream'?
You've done the hard work, now find pipe outside and replace whole of internal pipework with new UPVC pipe, joining to existing with stepped flexible clay to PVC adapter. Fill void with weak mix 15:1 concrete.
Here is where I got to with another few hours work.
I assume I will have to go quite a bit further 'downstream' to get to a part of the pipe after the bend to attach to?
You will need to dig back to the end of the bend. It will (hopefully) be running horizontally after that. Cut it there and adapt to plastic.
Glad your doing it properly, instead of boxing the wc off the wall. Will look much better when you have finished.:hurray:
Keep digging Pal,
You have a long way to go before the difficult stuff begins.
I hope for you sake that bend doesn't connect directly to a junction.
looks alright the job quite impressive for someone who is not so familiar with plumbing.
Hopefully he won't have those old long bends the are pretty long , if so he has to chisel quite a bit 😉
I think the last two posts might have called it! 🙁
What do I do next?
Cut it before the socket. Adapt it from there.
Seems like it might be possible, can't see the bottom of the pipe yet so I can't tell how much straight pipe I have to play with, doesn't seem like a lot but I guess it must be straight at the point it goes into the socket?
How much straight pipe do I need for the rubber joint to attach to?
Keep going around the pipe, expose it so you can see all the pipe then post further picture. You are doing really well. If you are going to use a rubber sleeve coupling you need about 3 inches of straight pipe. If you use a clay to plastic socket about the same is safe
The bend goes straight into socket with cement joint, will be necessary to cut off socket to give tolerance you need to reposition pipe close to wall. Would still be much easier, if possible, to locate pipe outside and make connection there. This would ensure all internal pipework properly jointed and reduce chance of leakage weakening foundations.
Sorry, missed you suggesting this in your earlier post. Are you suggesting I remove the entirety of the pipework I already have (all the way to the outside drain) and replace it. Or add additional pipework from the outside drain to where the new toilet is going to go? Or neither of the above?
Wouldn't that mean that I need to dig up a lot more of the floor to take it the full distance to the outside?
Can you elaborate on what your plan would be?
Assumed pipe was against outside wall, if not have to be done internal. In every case, if you have to dig a hole, dig one big enough to work in.
Not much progress tonight, sorry about that, I know people look forward to my posts about my bathroom soil pipe! The under side of the pipe above the joint is cemented in and very hard to get through. I have attached pictures but I'm not sure they are very useful in terms of people giving me advice.
What I am mainly wondering at this point is whether I could cut it off below the joint as the only thing surrounding that part of the pipe is soil and very easily removed.
Also not really sure, even if I do clear the remainder of the upper part of the pipe without breaking anything, whether I will have enough straight pipe to attach to?
Yer getting there. Get into it with the angle grinder or if you're brave enough you can just knock the collar off.
Try and break the vertical pipe off so you can clear the concrete.
All the concrete under the pipe will have to come out.
If you break the collar - you break it - chances we take.
Once you have cleared a section of the horizontal pipe then you can attempt to cut it.
And watch out for sharp edges on the earthenware - sharp as a scalpel.
Thanks, that was the plan I had just come up with also. Just dug around the pipe below the collar and that is all concreted too. Will cut the vertical section of the pipe off and see what it's like from there.
Have a feeling I might be buying a 240V SDS drill will chisel attachment before the end of the day!
Good progress this morning. Decided to start cutting off the upper pipe above the collar a bit at a time and seeing what I was left with after each cut. The concrete on the underside of the pipe wasn't too hard to break down once I got access.
Here is where I am at. I was hoping I would get a clean disconnection from the collar but unfortunately a bit of the collar broke off. Probably not too big of a deal in terms of the end goal, but I am a perfectionist!
So, is the next step to cut off the pipe below the collar and attach the rubber pipe coupling or is there a different play here?
Edit: This forum seems to attach photos in a different manner each time, I don't seem to be able to view the attached picture in a larger size so here is a link to it:
https://goo.gl/photos/6byhFU2i19qk8ny26
With no replies I now just feel like I am 'live blogging' the removal of my bathroom soil pipe! Cut off below the joint and removed all the concrete underneath, which was a real pain. Need to square off the cut (couldn't cut completely through at one angle due to access at the time) and then I am ready to put on the rubber coupling I guess?
To square the end of the pipe I guess I just cut a small amount off, wouldn't be better off getting a grinding disc and 'sanding it' square? I'm guessing probably not, but just a thought I had...
looking good so far and keep in mind most people will be still at work
and hope this helps
to help with cutting pipe bigger than your grinder can handle
cut the top section (blue line) upto red line and remove the piece
then you can get your grinder into the pipe so you can but the bottom from inside the pipe
hope this helps any questions just ask
I would say ...
A. You`ve done well.
B. The rubber collar will go over the pipe by around 3" so the end of the pipe is good enough.
But have a cup of tea and wait for replies from more experienced people than me.
I didn't mean to come across as if I was complaining about the lack of replies, just more amused that I was just posting a running commentary on the removal of a bathroom soil pipe. Hopefully someone will come across this in the future and the detail will help them.
Went and tidied up the end of the pipe a bit before I saw your post and thankfully I managed not to wreck anything, would have been massively annoyed if I had though considering it wasn't required.
Now I just need to figure out what I need to buy and go somewhere to buy it.
Measure the dia of the pipe and either go to a builder merchant or have a look on the Internet for a fernco coupling from dia of your pipe to 4"
Excellent job, coupling will seal as it is, but the square cut would be even better. Rub circumference of cut external and internal with piece of broken concrete to remove sharp edges. This will help coupling slide on pipe, external, and lessen chance of waste build up at joint, internal. Most important, old and new pipework adequately supported. I would use weak concrete mix. Some building inspectors might prefer pea shingle. Whatever you use pack it well round the pipe.
Bit of an hard question to answer I would imagine but what is the best way to work out what combination of bits I need in terms of angles and straight bits of UPVC pipework after the coupling?
Yes one straight bit how ever far you want to push it back/ toilet (but they might only sell a length ) and a 4" elbow
And then for above ground you will require a 4" bent pan connector
Small point, is there a recommended torque for tightening the bands when fitting the Fernco coupling?
Reply to the thread, titled "Moving Earthenware Waste in Concrete" which is posted in UK Plumbers Forums on Plumbers Forums.
blawford,
blawford,
