Multi-fit connection for 38mm chrome waste pipe?
View the thread, titled "Multi-fit connection for 38mm chrome waste pipe?" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hi all,
I'm in the process of fitting my freestanding bath. The supplied waste chrome pipe that runs into the floor is an unusual diameter - 38mm (European?). The bath came with a PVC multi-fit coupler to connect this chrome pipe to standard plastic waste pipe but its to long once I get under the floorboards as I can't achieve the fall. Does anyone know where I can find a multi-fit 90 degree bend which can accommodate 38 - 40mm? Cheers.
Have you tried using one of the washers from the coupling in the mcalpine ?
Yeah, Ive got both here - 42/43A and the 32/35A - either too small or too big. I haven't got the multi-fit coupler that came with the kit on me, its back at the house. I'll try the washer that came with that.
This doesn't have to be a chrome fitting btw, it'll be under the floor. There must be something out there. I'll also ask the seller tomorrow.
Might be best replacing it to uk stnd size eg
Yeah, £70 I'd rather not spend bearing in mind I already paid for waste, and who knows if it will fit the bath lol. The technical drawing on the sellers website with the dimensions is too low rez to make out, another reason to moan at them.
Reply to the thread, titled "Multi-fit connection for 38mm chrome waste pipe?" which is posted in DIY Plumbing Advice on Plumbers Forums.
kristeva,
kristeva,
