J
John_
With modern boilers, a lot of their error codes will tell u exactly what is wrong - is there a need for multimeter for fault finding?
How else would you check for safe isolation and do your earth tests
because if they did it would prove that most of what they do is unnecessary ,all health and safety is a self feeding monster that must eventually eat its self whilst ive no wish to go back to the days when labour was expendable it now getting ridicullusWhy is it usually so hard to get officer workers to understand or listen too the workforce in the UK?
The martindale units are great tools. Even better when paired with their proving units.i was taught to use a volt stick to prove the casing wasnt live and then procede with the standard tests with a muti meter the martidale you refer to i assume isnt a plug in one ? since most fault finding guides issued by manufacturers seen to indicate the use of multimeters thats what i will continue to do
