My electric shower just went bang!
View the thread, titled "My electric shower just went bang!" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hi guys, just stumbled across your website, and it looks great! Hope you can help me!
I turned on my electric shower at the weekend, and whilst getting undressed to step into it, there was a loud bang! from the shower unit and it cut-out. It was installed brand new around 15-18 months ago (it's a straightforward electric shower), albeit with existing fuses/cabling/switches from the previous shower.
I appreciate it could be any number of causes, but how/where do you recommend i start to look?
p.s. the rcd fuse had tripped, so later in the day i reset it, ran the shower on the cold setting for a few minutes, but as i slowly increased the temperature it went bang again.
On no account use it again until it`s been looked at !
Looked inside one for a neighbour last year after making certain the power supply was off and found burnt wiring inside.
Thanks for your comments guys. I did remove the cover and there no signs of burnt out wiring, which surprised me! The shower is a Galaxy Obsession 9.5kw. The cabling is 10mm. The rcd is 40amp. The cabling runs through my loft, approx 5 metres in total from the fuse box to the shower unit. I fitted it myself, and although i'm not an electrician, i'm a competent diy'er. However, i'm out of my depth here, hence posting on here, and what i'd like to know is should i call in an electrician or can i do some tests myself? I don't want to just rush out and purchase a new shower unit, as it's possible the problem lies elsewhere?
A new shower will be cheaper than paying electrician plus parts to mend existing. If you want to mend yourself confirm fault in heating element by checking resistance. Isolate until fixed/replaced.
Have you tried fault finding in the make/model of shower? Or even called the tech dept to ask their advice?
There's something not quite right as we all know.
I'd recommend looking at the fault finding or making a call.
Not an electrician so just highlighting 10mm cable over 5m for others to comment on. Thought it was more to do with diameter of core cables rather than overall diameter.
Make sure casing not obstructed / built in , lots of modern stuff wants to breathe
( as it loudly pops .. rather than losing cover ! )
We cannot be your eyes , so an experienced 2nd pair is still a good option .
all i will say is
YOU CANT FIT ANY ELECTRICS/APPLIANCE IN THE BATHROOM UNLESS YOUR A QUALIFIED SPARKY AS IT A NOTIFIABLE AREA
LEAVE THE SPARKS TO THE SPARKS
needs a bigger rcd.
sounds like the element is overheating and tripping out, the bang could be the water shutting off!
could be a faulty shower overall, call them to service. or an electrician to trace.
might be even a earth leakage to pipes, is it bonded?
Just had a chat with a pal of mine who is an electrician, recons 10mm cable 5 to 6 mts is borderline for that size shower
I am not an electrician, but I doubt that. 5 or 6 metres is a very short distance. Shower MIs also tend to keep on the very extreme safe side. 6mm cable will put a lot of power through it, so 10mm is plenty for 9.5kw. Have you ever noticed how small a cable supplying a meter to an entire house is and on a 100amp fuse?
One thing that MIs don't like is cable run in insulation or conduit for long distances.
you are right i would of said something but didnt want to go of topic but depending on which method you use (installation) 10mm will carry 55 amps and in a max sort of way the max you could go is 65m
zs and ze rubbish
short of it (11.5 x 1000) ÷ (4.4 x 40) = 65m (thats with a load about 45amps)
Thanks for all your help guys, i had an electrician look at it last night, and it is indeed the heating element in the shower that has gone. Dissappointing as it was barely over a year old (although it was purchased around 5 years ago but sat in my loft for 4 years!). He checked out the wiring etc and everything else is fine, so i'm now in search of a new shower. See new post........:vanish:
zs and ze rubbish
I might appear a bit silly here but what do the figures elate to?
I get the calculation result of 65mtrs but where does the 11.5 x 1000 & the 4,4 x 40 come from?
Just trying to learn something 🙂
You have committed a criminal offence by fitting that shower yourself if it was not signed of by building control. It's the electrical version of DIY gas boiler repair and fitting. Fitting that shower is notifiable to building controls under Part P for a reason. Get a qualified self certifying electrician in. I am surprised only Shaun has picked this up.
Reply to the thread, titled "My electric shower just went bang!" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
ADRIANPBIRD,
Radioman,
