View the thread, titled "Need advice on stock" which is posted in UK Plumbers Forums on UK Plumbers Forums.
M
madmax2002uk
hi all
i am looking on getting self employed and am working on my business plan, i have researched the pros and cons associated with different training methods, methods of getting a van and a few other things.
what i need advice on is what stock a good plumber carries on the van and what kind of quanitys as i would like to start building stock up while waiting for training to begin
i would appreciate your advice on this matter and thank you for your time
it all depends on what sort of work your getting you would be better trying to keep your stock low to start with once the work starts coming in then you will know what you are going to use and not waste your money, most jobs you will need to quote for and when you have quoted you will know what you need for that one job, you can always nip out for somthing if you need to, if you have a lot of stock on your van and it gets robbed you've lost a lot and need to buy it all again, just carry the basic's pipe/conections, service valves, bath water trap, basin water traps (P, S, Bottle) sink trap, tap washers, O rings, solder, flux, ect
as said it depends what sort of work you want to do.
ifyour doing general plumbing bathrooms etc you can make a note of what you need when you go to quote, sods law if you have a part on the van it will be another type or lenght that you need for the job.
if you plan on doing 24 hour you'll need a lot more.
i do 24 hour and also sub to a housing association,& 2 calll centres
and we have to carry most everyday parts as 99% of jobs are to be repaired on that first visit.
we carry a stock of your usual everyday parts or parts that are most common to fail everyday
part 2 float valves, e/f fittings, radiator valves, isolation valves, compression fittings, flexi taps connectors, various sized immersions,
stopcocks, overflow pipe-fittings, washing machine fittings, wc spares - do-nuts - syphons - float valves, solvent weld pipe fittings the list go's on.
Reply to the thread, titled "Need advice on stock" which is posted in UK Plumbers Forums on Plumbers Forums.
