Need help identifying radiator valve
View the thread, titled "Need help identifying radiator valve" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Is anyone able to identify this radiator valve please? I would like to source a replacement valve cap/knob (whatever the correct term is)
Thanks in advance.
Very old Danfoss has a clamp and screw to fix head on. New heads available but pricey
Looking on Amazon there are a number of head options.
013G5023 and 013G6040 appear to be for newer valves but this one which is described as being for old ra/vl 26mm bodies:
Danfoss - Thermostatic head for old Danfoss RA / VL 26mm bodies
Does this seem right?
And it works ? Eg turns off at set temp ?
It seems to be working perfectly 🙂
I actually purchased the head recommended above but it didn't fit. I contacted that company and provided the naked valve photo and they advised me which head to purchase. Just gotta return the first one.
I updated this thread so anyone searching for a solution to the same problem would find the solution.
Reply to the thread, titled "Need help identifying radiator valve" which is posted in UK Plumbers Forums on Plumbers Forums.
mrpcpearson,
DrNo2021,
