Need help with some of my gas engineer course questions?
View the thread, titled "Need help with some of my gas engineer course questions?" which is posted in Plumbing Courses on UK Plumbers Forums.
I am currently studying to pas as a gas engineer and I have come stuck on some of The modules and can’t seem to find the answers anywhere.
Q1. A gas meter can be installed without a mounting bracket or support shelf, only when
A1. The supporting pipework either side Is constructed of rigid stainless steel which runs at least 600mm either side and is clipped/supported
A2. It is installed in an area unlikely to be disturbed
A3. It has been installed and signed off by the gas supplier
Hope someone can help. Thanks
The answer used to be A, but guidance on current regulations state that the meter must either be mounted on a supporting bracket or standing on the floor on plastic feet.
Thanks for the help. Some of the modules are a bit dated and the supporting documents to each exam can be from 20 years ago. This part of the course is only to give me a head start with understanding why things need to be done when I go on site. I appreciate the help. ill be sure to return if I hit anymore roadblocks.
You need upto date content trust me if you load yourself with old stuff you will 100% fail so much has changed in 20 years the industry is so tight now you will fall !
Answer a3 if I remember if there’s no bracket It has to have a rigid copper pipe at least 600mm but a1 state ss so I’d say a3 unless Scotland regs are different to uk
Reply to the thread, titled "Need help with some of my gas engineer course questions?" which is posted in Plumbing Courses on Plumbers Forums.
Tpritch,
Excite,
