Need help with the Boiler/water pressure in my flat :(
View the thread, titled "Need help with the Boiler/water pressure in my flat :(" which is posted in Boiler Advice Forum on UK Plumbers Forums.
408winter
Help please - last few days water pressure to hot taps has gone right down and water pump is running constantly. Have checked all valves and they are on full. 3rd floor flat but unaware of any local problems. Tank constantly refilling but unable to get a decent stream of hot water.
I have recorded a short clip to see if it makes any more sense.
Need help with my boiler!! - YouTube
Any help would be very much appreciated 🙂
The water tank is filling up with water constantly and does'nt seem to be heating up the water either. The water temperature coming from the shower is not very warm. There is a contant hissing noise coming from the pump.
Try turning the pump off at the switch, then give the tank time to fill up without using any taps.
When the filling noise stops - turn the pump back on & see if you have pressure back - the water temperature is likely to be a different issue
How long would it take to fill up? I switch it off at the mains during the night and when I go to work 7am - pm. As soon as I switch the power back on I still get that horrible hissing noise 🙁
you say the tank is filling constantly ? - doesn't the "filling" noise stop after a while ?
(ps your video on youtube looks like a winterthur way property)
Yeah it's filling constantly and i've tried to leave it going for a few hours and the hissing noise continues to go on.
Is it possible you've got a leak somewhere? Tank filling continuously, pump running continuously. Can you shut off the water supply to the tank and see if the level drops?
it could just be the ball valve in the tank that needs changing - but not having seen it I could be wrong.
Hope it isn't the pump - they're quite expensive.
when you say tank is filling do you mean the cylinder thats in the video if so is your overflow running water
Tried switching the supply to the tank off, and there does'nt seem to be a leak anywhere. There also seems to be a sufficient amount of water.
I hope so 🙂
It's been like this for a couple of weeks now and i've checked all the pipes for leaks ect. I read in the manual something about using a magnet to test the flow switch. When I did this and put the magnet to the reed clamp, the hissing noise was constant rather intermittent. Not sure if that means anything.
Please excuse my lack of knowledge.
Ring pump maker, think its a stuart turner (Henley) very helpfull they also do on site repaires, pump you have around £600.00
The pump could hunt on & off if it has a fault but If the tank starts filling at the same time it does sound like water is moving through the system.
When the tank is full & its stopped making a filling noise & the pump is turned on, is the bath hot tap pressure ok ?
Reply to the thread, titled "Need help with the Boiler/water pressure in my flat :(" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
408winter,
FamousVir,
