no external one anywhere fits been in about 10 years
Sweet Jesus get one fitted asap, and replace the inlet valve set, it will need a slight repipe as the control sets have changed 3 times since then, nowt hard though
Mark....expansion trust me work on these weekly........vessel on and water inlet control set, job, done.....hows its run for 10 years i have no idea, get me some pics for a laugh:grin:
ok but the incomings only 3 bar taken from a outside tap safety valves set at 6 bar,if i have 3 in hows this caused a 6 bar to go off?
The 6 bar pressure relief valve is there as a safety device. In your case it won't need to do anything if the PRV failed but in a property with 8 bar mains pressure, then it would discharge if the PRV did happen to fail.
It's all to prevent the pressure in the cylinder getting too high!
