Need your expert advice guys - unexplained pipe going into my wall..
View the thread, titled "Need your expert advice guys - unexplained pipe going into my wall.." which is posted in Central Heating Forum on UK Plumbers Forums.
J
Jennifer1991
Hi Guys,
I was wondering whether anyone had any advice on the following situation?😕
Problem:
I moved into a new flat recently and there is a bit of an odd smell in one of the rooms; I can't place exactly what the smell is though.
Details:
(please see picture attached)
On the attached picture, I can see an "unknown pipe" entering that room in the wall. I say unknown, because I have no idea that pipe is for!
The pipe is attached to another pipe, that is connected to the toilet, (the "toilet pipe" on the picture). This larger toilet pipe goes up to the roof, where i guess it vents off all the yucky toilet smells.
The only thing i can see the "unexplained pipe" doing, is carrying the smells from the toilet pipe directly into the wall of that room.
Questions for you guys:
- Does anyone have any idea what the "unexplained pipe" could be for?
- Any idea how i could find out what its purpose is? As it's flowing upwards, I can't imagine it removes any waste from the property
- Does anyone see any harm in removing it?
- How could I remove it? Do it from the outside by cutting it off (it seems to be metal), or open up the wall in the room and do it from there?
Thanks for your expert advice in advance!
Hi Jennifer and welcome to the madhouse.
Have you any flats above you?
The way that pipe runs it has to be a vent pipe.
Thanks for the quick reply, Croppie!
We are a top floor flat, and don't have any flats above us (only a roof)
Excuse my dizziness, but what would a vent pipe be used for in a bedroom? Also, would you expect it to be connected to the pipe that carries toilet waste and yucky smells?
I was wondering what would happen if I had it sealed off...
Jenni😕
Actually, regarding the flats above us, there is a flat to the immediate left, and a little higher up, that has a bathroom that connects into that main toilet pipe..
Jenni
Reason I asked about other flats is because my immediate concern would be over the possibility of foul water and solids getting down that pipe!
Nasty niffs are bad enough!
The pipe you're concerned about, does it join the stack above where any other toilets are tee'd in?
Thanks again Croppie. Let me take another picture for you and show you the full layout, I think your expert view on the picture will allow you to see it a lot more clearly than me trying to explain it 🙂🙂
Will get back to you 😀
this advice is priceless to me, as my plumbing knowledge is a little on the low side, to say the least! 🙂 will get back to you with the pics, Croppie 🙂
Hi jenni,
How long have you lived there, how far in to the room does the pipe come, is the pipe that comes through the wall rubber, plastic or metal and is it around 22 - 30mm diameter? Also are there any signs of a basin, shower or toilet having been in the room in the past?
Just wondering if a macerator has been removed and the pipe wasn`t. Probably best to cover the end of the pipe with a strong plastic bag and secure it to the pipe with a jubilee clip or strong tape for now.
Just an old style air admittance pipe used to stop traps etc syphoning out if you look at photo you can see its not connected to the stack, but may do at a higher level probably old lead pipe.
JTS Plumbing, RPM, Croppie, thanks for the kind replies 🙂
I have attached a few more pictures, which show the bottom, middle and top view of the situation.
RPM, for your questions:
1."How long have you lived there?" - just moved in!
2. "how far in to the room does the pipe come?" That's the odd thing, the pipe does not show on the other side of the wall at all! It just disappears, so I've no idea where it goes..
3. "is the pipe that comes through the wall rubber, plastic or metal" the pipe outside the room is metal I (think?) i don't know what a lead pipe feel like (then it disappears when inside the wall, so doesn't show on the other side)
4. "and is it around 22 - 30mm diameter?" I'd say it's narrower - around 10 cm in diameter
5. "Also are there any signs of a basin, shower or toilet having been in the room in the past?" From inside, I can't tell,however, if you look at the "middle" photo, i can see a circular pattern of new brick, which indicates something was there in the past?
JTS Plumbing/rpm/anyone else, is it your conclusion that this is a redundant pipe then? And if it's not sealed off, then I should definitely seal it off?
- I guess I'm going to have to open the wall in the room and seal it somehow?
- I guess there's no way to trace whether it's used in the adjacent loo somehow - it seem to far away from that room to be used..
- If I need to open up the wall and seal it, who would I ask - do I need a plumber? just need the name of the type of handyman i need to google 🙂
Thanks in advance guys!
Jenni
looking at the new photos I can see the pipe is much larger than I first thought so in that respect ignore everything I said and listen to the others.
Im out!
Needs getting out the wall as you'll be getting some moisture down it in heavy rain.
I'll second it then if you're taking firsties.
Thanks all, for your kind help 🙂
Seems like I can get rid of this, then.
Is there any danger if I just cut if off, so it terminates just in front of the wall? (I.e. it is kind of left, "dangling" there), or does it need to be taken all the way back to the stack?
best to cut it back as far as you can. Then if it does leak it wont run down your windows and the smell will be further away from your window. Maybe have a word with the neighbour who has the other part into there wall and discuss if they want it removing as well. could share the costs if you get somebody in.
:iagree:
I was wondering about the other pipe where that vanishes into the wall too.
Either way, decent plumber can remove the vent, seal the stack and make good the wall.
I'd heartily recommend any of the guys off here. Whereabouts are you Jenni?
Thanks AWheating!
By the way, are these vent pipes only something that's needed on old toilets? I'm wondering if I should be concerned that it's not connected to my new toilet.
The reason I ask, on my new toilet, it has a push button flush and it i need to push the button four or five times before it catches. When it does catch and flush though, the flush strength is fine though. Just asking, because people here were saying that the pipe helps with pressure.
Maybe my toilet problem is more related to a defective flushing mechanism though?
Thanks in advance
Reply to the thread, titled "Need your expert advice guys - unexplained pipe going into my wall.." which is posted in Central Heating Forum on Plumbers Forums.
Jennifer1991,
Jennifer1991,
