But seeing it changed your life - NOT... 😎
Actually a good point. If, genuinely, anyone is interested in a kit then I'll do you horrible lot £25 off. If you're interested let me know & I'll give you a code.😵😵😵
How much is it? Also, I think it is ok to promote as long as it is not you doing it.😉😉😉
What’s in the kit?
Best oook online tapmedic or
store
What’s in the kit?
Number at start is what's in, number after is capacity.
1 x Aluminium case – lockable
1 x Protection mat (1)
2 x HD polypropylene foam liners (2)
1 x Separate component box (1)
1 x TM® cutting jig (1)
2 x TM® Allen keys (4)
8 x ½” cartridge bodies (18)
4 x 3/4" cartridge bodies (12)
12 x Shroud adapters (50)
14 x Shroud adapter clips (50)
12 x Short flanged head handle screws (50)
6 x Long flanged head handle screws (50)
4 x Short grub screws (spares) (50)
4 x Long grub screws (spares) (50)
8 x ½” body extensions (18)
8 x ½” grey end seals (24)
8 x ½” black end seals (24)
4 x ¾” body extensions (15)
4 x ¾” grey end seals (15)
4 x ¾” black end seals (15)
8 x 18 splines 7.6mm dia 35mm long spindles (20)
2 x 18 splines 7.6mm dia 55mm long spindles (5)
2 x 18 splines 7.6mm dia 75mm long spindles (5)
10 x 20 splines 7.6mm dia 35mm long spindles (20)
2 x 20 splines 7.6mm dia 55mm long spindles (5)
2 x 20 splines 7.6mm dia 75mm long spindles (5)
8 x 24 splines 7.6mm dia 35mm long spindles (20)
2 x 24 splines 7.6mm dia 55mm long spindles (5)
2 x 24 splines 7.6mm dia 75mm long spindles (5)
8 x 28 splines 7.7mm dia 35mm long spindles (5)
2 x 28 splines 7.7mm dia 55mm long spindles (5)
2 x 28 splines 7.7mm dia 75mm long spindles (5)
20 x 3mm handle sleeves (160)
10 x 4mm handle sleeves (128)
10 x 5mm handle sleeves (96)
10 x 10mm handle sleeves (48)
2 x 12omm handle sleeves (4)
You can specify a STD kit in any from 12 x 1/2" & 0 x 3/4" to 0 x 1/2" & 12 x 3/4". Same price.
Oh they also do shower valves too 🙄
Reactions: Harvest Fields
He did
How the hell did you get one? Not having you paid retail for that bad boy😛😛😛
He did indeed. Moreover, he ordered many more components than standard. Fact is, it genuinely works out really profitably as often you are replicating a £50 cartridge for £9.50!
Is the adhesive any good?
Oh gosh I'd forgotten about that! Hell we changed from that ages ago to a more robust, faster, safer and more reliable method. Its all now, genuinely, a piece of cake - hence the record time. When you saw it we had to wait 10 minutes for the adhesive to go off!!!
We did 140 odd demos whilst we were at Installer. 1, just 1 out of all of those people mentioned it being 'faffy' and it struck a chord with me. So 6 weeks later I'd redesigned it to what it is now and even I am happy with it 😱😱😱
Shaun charges too little 😕 cos he's too kind.
I'd charge a minimum of £20 a cart. Recently did two taps on back of a bath @£200 the pair. Saved the cust £1000 as he'd been quoted £1200 for bath out retile etc 🙂
