Looks a mess, along with the fact the condensate is in white when everything else is black. I'd get him back - as bricking up is part of the job and an attempt to get matching bricks should be made.
New boiler fitted, part of the install was to brick up the old flue, prior to the job starting the plumber asked;
'Do you have matching bricks for the hole that will be left, or he can bring his own but they won't match the colour of your house bricks'
My reply - 'Bring bricks anyhow, but I'll try and get some'. Seems quite clear the job involved bricking up the old flue
This is what has been done, advice please! Is this a suitable fix? This is concrete with lines drawn in to look like bricks. The fitter has since stated 'Well, I'm not a brick layer'
I've since been quoted £275 from a brick layer to put right
View attachment 27888View attachment 27889
275 from a bricklayer to put right... Seems a lot for half dozen bricks & some mortar! Shouldn't take too long!
What a Bodge up...
Looks like the condensate has just been pushed into the 4" soil stack as I can't see a strap on boss connector?, maybe just siliconed in lol...
Very lazy to use white, probs saved buying some new pipe & fittings... Same lazy excuse with the flue!
It has been siliconed in - there is NO strap on boss, I've queried this and been informed it's down to "personal preference when to use"
I thought it was quite expensive too, however this is the 1st quote I've been given
You need to get the installer back to brick it up which is what he agreed to do according to your previous statement. Even if you yourself go to a yard and spend a few pence on the right bricks, it'll be worth it as clearly it isn't something he's bother with, that's if you want him back of course.
