Guest viewing limit reached
New boiler Main HE vs Worcester CDI
View the thread, titled "New boiler Main HE vs Worcester CDI" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Burner gaskets pmsl look at the 133 HE.....
Fans now sorted EBM's problem WB take the hassle
Filling links don't have a problem my self as I leave them fitted lol
CDi is not a calibration mode it is a condensate fill which is entered after a power cut, or engineer mode mode can be deactivated via the menu 4F to be exact
The only one I can give you is the PRV, utter carp design, but I don't worry about them for 7 years anyhow
and i dont worry about the 133 wont work on them at all,just replace for duotec 1/gold combi(wont fit GA),but your bringing past boilers into it,the 105 for example was a cracking boiler,worster could not make one this good,at the time they had the 24 and 28i junior a boiler well known for a very dangerous fault,the pcb fails and melts the top end of the boiler,the baxi ga range is tat,however stick a greenstar next to a duotec one its easy to see which ones better designed
Personally I think vern has said all the reasons why i hate wb, you have to know all the various codes to get it to work, let alone diagnose the breakdowns. All I want is simple to work with and on, not reams of indexes to investigate and setup something, just more to go wrong in the short term. I'm not saying intergas are perfect but at least the diagnostics can be done by most gs techies who dont have to pay to go on a course to be told what should be in the servicing manual already and get a free diagnostics card.
none of us will ever agree on a boiler choice, Baxi will never make a full range of reliable boilers,only some good ones(GA and solo HE are pants,and Worcesters will never be brass components and always suffer incontinence,and ideal will never win which? boiler of the year LOL
Serious question what's bad about the solo HE? As you can fit these on 3 wires no perm live or pump over run to worry about!
133 in disguise,about to either change one i fitted 2 years ago or baxi are sorting it,out 10 times in its first year every part changed at least twice worked for a bit then hex started whining 2 years later same noise again
Will avoid then pal, have a job coming up where a WB Ri will be a nightmare because of wiring, so the solo would fit the bill, will have a rethink or move pump
Reply to the thread, titled "New boiler Main HE vs Worcester CDI" which is posted in Boiler Advice Forum on Plumbers Forums.
pj_eden,
vern,
