Installing a magnet is mandatory on any new/replacement boiler these days and thats not open for debate. To say a system doesn't need a powerflush and the magnet alone is enough is really quite naive.
Thank you. Looks like we will have to get another plumber. As I said very nice lad but he doesn't know what the problem is. Not long in the profession.Installing a magnet is mandatory on any new/replacement boiler these days and thats not open for debate. To say a system doesn't need a powerflush and the magnet alone is enough is really quite naive.
Could it have been a magnacleanse machine?Installing a magnet is mandatory on any new/replacement boiler these days and thats not open for debate. To say a system doesn't need a powerflush and the magnet alone is enough is really quite naive.
Update. Got the engineer back. He looked at the one that comes on gets very hot and then goes off and stays off . He said trv was stiff took it off wiggle pin. It heated up. Of course he went and it switched off again. Others still cooling off quickly and only get a bit warm again. I am having to keep the couple that do work on 5 to get them to stay on. House thermostat never reaches its max. So house not too hot. These as I said are new Tower Trvs . Now my old trvs never turned the rads completely off stayed on all the time at the output we set. He said new systems are different I just want to cry. Surely the rads shouldn't get that cold for that long. Any adviceOne indication of large sludge build up in the system is to get a strong magnet and offer up to the copper pipework in several places. Copper cannot be magnetised but if there was magnetite (sludge) in the system the magnet would adhere to the copper.
It was supposed to be a Baxi 18. When he came he asked me what it was I dont know how to check what he fitted we just trusted themNo they shouldn't. Under normal working conditions the trv's will stay open until target room temperature is met, whereby they throttle in. Was the new boiler sized correctly? As in is it's rated output the same as previous boiler?
I think your right. Funny it worked when he took trv off. I told him it would go off after a bit permanently but he had to rush off. The boiler warranty says baxi 418 so I guess it is the right size our gut feeling is the cheap Trvs. He said all new systems go off completely. Because my Husband is elderly and so am I and female. He wont believe us. When I pushed him on why the trvs completely go off till rad is cold, he said it is hard to explain. He is such a nice guy but we have spent thousands, we are not wealthy and it looks like we will have to get in a new plumber and start again. He honestly, just does not know why it happens. Is it possible for trvs to be too sensitive to temperature levels. We can't be the only ones to ever have this problemSo he made no note of previous boiler output or did any heat loss calculations? The problem you're experiencing with rooms never coming up to temperature can be caused by an undersized boiler but I still think you have something else going on. Even if the new boiler was undersized you would still reach a certain indoor temperature, the fact you say rads warm up then go cold for ages suggests something else is going on as well.
Thank you. I will put a new post on re this brand of trvsIt is possible that the trv's are at fault, in which case it would be a manufacturers responsibility under warranty to fix.
I think these are around £5No, I'm afraid or thankful that I've never heard of them. I replaced all (8) my 10/12 year old assorted ones but mainly Myson over the summer with "cheap?", around £12, EPH ones, all working perfectly well.
Just took trv head off rad immediately hot. Let's see if it stays hot. Thank you will updateTower I believe are in the lower price bracket, and in my experience I would tend to stick with proven named brands such as Honeywel, Drayton, Pegler et al.
Are you able to remove the trv heads? If so, you could remove the ones where fitted and see how long they stay hot for and if the rads are indeed getting hot?
and get some neighbor that has a hammer (no don't do that), get him to reverse it and us the handle to push the pin(s) in (they should then spring out but only move ~ 3 to 5mm)Tower I believe are in the lower price bracket, and in my experience I would tend to stick with proven named brands such as Honeywel, Drayton, Pegler et al.
