New Central heating but problems, Please help
View the thread, titled "New Central heating but problems, Please help" which is posted in Central Heating Forum on UK Plumbers Forums.
Hi.
hopefully someone can help me here.
I have a recently had a new gas central heating system consisting of 7 rads and a Worchester 36cdi compact located in the lofty controlled by the wave thermostat.
I used to have electric storage rads and the electric controlled heating with were on tanks.
after install i have a drop in hot water pressure. if the cold is on then the hot drops and even running the bath takes forever.
any ideas?
i want to make sure i have all my facts straight before speaking to the plumber who installed as he did come arounf measureing pressure and said it was about average on the set up up i requested.
the main in pressure was 3 bar and the flow was 14l/m with the hot being 10l/m.
thanks for your help in advance
You need to call back the installer to check water flow your about 3Ltr per min short on hot water delivery,
He checked flow when I was present.
Everything is open.
I have 15mm that enter house that run in the loft but then goes to 22mm. Would it help to increase to 22mm from 15mm pipe.
The flow seems fairly quick on top taps on sinks but very poor on bath.
All your outlets are 15mm to the hots but on your bath i presume its still old 22mm probably delievers the same litres per minute just seems slower.
The flow on your boiler will be preset. Im not 100% familiar with your boiler but id say 12litres per minute. Thus cant be adjusted.
As for the 22mm to the bath. Ideally it should be 15mm from a combi...you may find you have to draw off alot more water before it becomes hot.
Tbh it's sounds like there's not much wrong. Your water main is giving 14lpm. Your getting a little less once the flow has been restricted by your pipe work and boiler. If you open the cold then it is sharing the 14lpm with your boiler, probably have less restriction than your boiler it gets more of the share.
1. Your boiler will provide 13 lpm at a 40 degree temperature rise, plus or minus 15%. If you're unlucky, and its minus 15%, the maximum hot flow rate will be about 11 lpm. Also, the Compact ERP version has a flow restrictor to limit the flow necessary to ensure that 40 degree, which may also reduce the flow rate.
2. The hot (and cold) flow rate at the bath outlet will be lower than an open pipe immediately after the boiler, as it has to navigate the pipework and fittings / bends. Friction in the system will reduce the rate of flow.
3. With a tank system, the hot and cold flow rates are largely independent as both come from large stores of water, usually (in the case of a bath) via 22mm pipes. With a combi, the cold comes off the mains via 15mm pipe, and the hot also comes off the mains via the boiler, again with (usually) 15mm pipe.
4. It would help to know what the cold mains flow rate is at the point of entry to your property. This would give you the maximum possible flow rate for both hot and cold. Measuring separately at the bath taps doesn't give you a full picture.
Thanks for this.
I have measured all taps and the all cold measured around 14-15 Lpm and all hot is around 9-10lpm. The mains in is on 15mm until it gets to the loft transferring to 22mm it then runs the length of the loft to other side to where the boiler is situated.
Should I be lose 4-5lpm on flow just going via the boiler?
Thanks for this.
Check the instruction manual for the boiler. It will tell you roughly what flow rates to expect at what temps. But as stated above this is a rough guide only and may not be spot on.
I am being advised by the guy who installed the system an accumulator will give me the max pressure the boiler can cope as effectively it's a storage of water so I can fill 2 baths at max flow.
Combi boilers will never fill two baths they struggle with one
In my opinion a combi will never run a bath and a shower at full rate together let alone 2 baths.
Chap I work with always increases mains to combis in 22mm all the way. He doesn't win jobs on price, but gets a lot from recommendations.
At home I only have 15mm but family have learned not to turn tap on when anyone the shower. Even thought of putting a solenoid valve on mains but managed so far. also we turn dishwasher and washing machine off. You learn to live with it. Worse at 7-8 in the morning when incoming pressure low. Might put in mains boost pump.
I am struggling to understand.
I have spent 5 grand on a new combi boiler to control heating and water from electric storage rads and electric thermostat controlling the water in a cylinder. The hot flow was as good as the cold.
I am prepared to spend more money to get the flow up but what is a guaranteed fix to improve flow on hot?
Reply to the thread, titled "New Central heating but problems, Please help" which is posted in Central Heating Forum on Plumbers Forums.
Dale Sanders,
ShaunCorbs,
