View the thread, titled "New Combi installation, 2 radiators working, one up one downstairs the rest are cold?" which is posted in Air Sourced Heat Pumps Advice Forum on UK Plumbers Forums.
bruvvamoff
Hi all
Sorry if this question has been done to death but every case is different as they say.
I just had a combi installation (Ideal logic 35kw) and the hot water works fantastic but not the heating.
I turned it on for the first time this year and only 2 rads worked.
I went round and bled every rad and the pressure dropped and the boiler shut off.
So I opened the boiler valves to refill the system as instructed by the plumber and the boiler came back on but still only upstairs bedroom and downstairs hallway radiators work.
Now my plumber is on holiday.
Any ideas?
Re: New Combi installation, 2 radiators working, one up one downstairs the rest are c
Has the heating ever worked with the new boiler?
The guy tested the system and all the rads were working on test but that was about 3 months ago. I tried it recently and only the 2 rads work.
Shut down all the rads and open them one at a time to try and narrow down the problem. See if they work individually first
as above close all the radiators and open one when that gets hot turn it off and open another and keep doing that then open all of them .they may need balancing
Someone said to turn off the radiators that work and turn the heating on which I tried but the others didn't get hot. I'll try turning them on one at a time.
You say you bled the rads until the boiler cut out, then you topped up the boiler.
Did you then repeat the process until you got water from every bleed point on every rad?
Oh and turn the heating off while you bleed them. might be handy to have someone at the boiler to keep topping up to 1bar while you bleed each rad.
wait for your plumber to come back, its summer. If he/she commissioned the boiler correctly all the rads should be working fine.
i assue you have turned up your boiler stat,trv's and room stat?
Simply , the plumber should nt be on holiday , tut tut
Thanks for all your replies. I figured it out, the input valve on the living room rad was closed. Opened it up and the rest of the house warmed up.
if you have one valve closed and the house goes cold then you really need another plumber to check out your system!!!
sounds like he tried plumbing in a rad flow and retun onto a single pipe sytem, and didnt realise it was single pipe!!
sounds as others have said like a one pipe system he should have changed to a 2 pipe system
One pipe will will work fine on with all rads off. Sounds more like it was flow rad.
although its recommended to upgrade to a two piper a one pipe system normally works fine if balanced correctly and restrictive rad valves are not fitted.
Ive installed new oil boilers on a one piper with no issues. Cust too tight to upgrade.
Just done the same this week, but custard is wanting several rads moved/ removed. Only issue, 5 kids and divorced mother means crap everywhere and she is also extending upstairs and in her garage so its shambolic!!!
Plus the new ext boiler install was 2nd hand , so had to remove and transport that. Then she wanted her oil tank moved off a high plinth etc etc, how we achieved the move is
only for the arms🙂
Reply to the thread, titled "New Combi installation, 2 radiators working, one up one downstairs the rest are cold?" which is posted in Air Sourced Heat Pumps Advice Forum on Plumbers Forums.
