View the thread, titled "new condensate gizmo" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Billy Bob Bob
made by Worcester it sits around the flow and only lets the condi go in a big gulp of heated water it prevents freezing so thought i would try on out on this potterton gold combi fit,the pipes lagged in waterproof armaflx,buried in the concrete chase and wrapped in denso ,also heres the prv terminal i have used quite a lot recently
was showed them in worcester factory a few weeks ago. Looks like a good idea, what was the cost?
bit rough gasman :wink:
you not got a burn mat :smilielol5:
i also leave a tidier job than that :biggrin5:
just realized flue is in the shot as well,that should not be LOL
Clever piece of kit, the elbow part of the connections can also be cut off to enable straight connections instead of elbows.
Not criticising your pipework, Johnnyplumb has already done that lol.
as already said its being boxed in,why work hard to do neat work when its not going to be on display if all you lads want to do is criticise i remove the post heres me thinking i was being helpful showing new products on the market
there's that prv pipe as well , been drilled from the inside, made a right mess of the wall too :disappointed:
Reel the neck in gasman, I mentioned the fact the elbow part of the fittings can be cut off.
The first time I looked at one of these about 6 weeks ago I was in the local merchants with the local Worcester rep, my first comment was about the elbows coming off the unit.
When we read the instructions it shows that the elbows can be cut off. Sometimes when we open boxes we dont look to closely at the instructions because we dont need to.
I was not slating your'e pipework just joking that johnnyplumb was :38:.
Some may have looked at those pictures and thought the same as me? I also thought I was helping out others by passing on my experience.
Have a beer and chill out, mines a Stella.
Kev.
TBH wanted to cut the elbows this is where problems will arise,yet two find two brands of overflow that are a good fit some fittings are so tight they split when you put them on why cant they make it a standard size its all supposed to be 21.5 but often is not
universal overflow fittings with rubber seals like waste pipes, someone needs start making them.
Sorry for crap photo, wife looking at me like Im weird.
There are no markings on the fitting, it will take any size overflow pipe.
Reply to the thread, titled "new condensate gizmo" which is posted in UK Plumbers Forums on Plumbers Forums.
