View the thread, titled "New feed for Shower pump" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Bennyboy1974
Hi all,
I am going to fit a salamander shower pump over the coming week and reading the instructions, it recommends 22mm pipework apart from the last 2m to the pump, as my CWSC is quite a way away from the cylinder, I am going to renew the pipework.
At present, the cold feed to the shower is in 15mm pipework and comes out of the side of the CWSC, not opposite the ballvalve inlet. The instructions again recommend opposite entry to prevent air getting in the pipework i assume.
Are there blanking plugs/caps that i can use on the existing 15mm tank connector or is it ok to cut the 15mm back close to the tank and use a compression blanking cap? Then i can proceed with installing a new 22mm tank connector in the tank?
Basically want to do everything by the book so as not to invalidate the warranty.
Hope that makes sense? It does in my funny little mind!
Cheers all and have a great Easter all of you.
Ben
I'd cut it back as close to the tank as you could get it and cap it horizontal. What you want to avoid is a dead drop of pipe full of water that will just sit and breed bacteria.
You might want to take the existing pipe out of the tank connector and make up a little straight stub with a compression cap end on then put that where the old pipe was.
If it was me doing the job I would remove the existing 15mm T/C and re drill a larger hole then replace with the 22mm T/C, can be fidderly but that's how I do it.
Reply to the thread, titled "New feed for Shower pump" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
