new glowworm betacom
View the thread, titled "new glowworm betacom" which is posted in UK Plumbers Forums on UK Plumbers Forums.
ambrosia
has anybody else had trouble with the PRVs when installing the current Betacom
the pipework screws up into a plastic fitting, metal to plastic is never a good idea but in this case the plastic seems to be particularly soft and easy to thread
a coleague had problems a months ago and i had the same thing last night,
it really is a bad design and in the future when PRVs need replacing its only going to get harder
After yesterday i'm not going to fit any more until they fix that design flaw
(also i find it annoying they no longer have a pressure gauge)
do you reckon anyone from glowworm reads these posts or am i just ranting
Yeah, I've had this problem too. Might be best to fit the PRV first before piping up the rest of the boiler.
the PRV is in front of the other pipework, if you do PRV 1st it makes everything so much harder
my solution is better, i'm not going to fit them till they sort it out
It is a bit of a pain to fit, it never wants to screw in. Other than that, I do actually quite like it as a budget boiler.
Bit of silicon grease works every time
The betacom ultimate has a pressure gauge inside the casting for the installer ➕the standard digital one
There reward club is excellent you can spend the rewards on I tunes, amazon etc and you don't need 10 million points before you can use
Just a straight £10 for beatacom2 and £15 for ultimate not sure about others and you can register warranty and gas safe notification cheaper
As said above, a bit of grease makes life easier. It amazes me who thought this was a good position when designing it.
Reply to the thread, titled "new glowworm betacom" which is posted in UK Plumbers Forums on Plumbers Forums.
ambrosia,
ed209,
