View the thread, titled "New Hot water tank help." which is posted in Plumbing Advice for Any Other Country on UK Plumbers Forums.
A
aaronh21
Hi
I'm installing an ECOCENT ESP100 unventilated hot water cylinder into my house to replace my old vented cylinder. However my mains cold water supply is unreliable and was wonder if someone could give me some advice on my proposed solution?
I intend to use the 50 Gallon header tank (from the old vented tank)I have just above the new ventilated hot water cylinder as a cold water store, and then pump out of this tank using a Draper 64987 55L/Min Booster Pump into the inlet side of the new unventilated tank from this to give me a constant supply of cold water at a good rate. I have a 22mm outlet from the header tank and the new hot water tank has a 1/2" inlet and outlet. The hot water tank is to feed one bath, thermostatic shower and taps.
Any advice would be greatly appreciated.
Kind Regards
Aaron Hodgson.
Aaron. What's wrong with your water supply? Why don't you fix this instead of giving yourself a headache with what you're proposing?
Upvote 0
I doubt your gonna get any advice here seen as you dont sound qualified to what your proposing, get someone in who does know what there doing
Upvote 0
Hello Aaron,
is it the hot water or cold that you want boosting? I have reread the post several times and am not sure??
if you want to boost the cold the new pump from salamander that can be direct connected to the mains but regulates itself to a maximum of 12lt a minute might be worth thinking about.
if its the hot you are trying to get a better pressure with then why not fit a pump after the hot water tank??
your original post is scary, there are so many regulation potentially being broken in what you suggest doing.
an unvented cylinder is potentially very dangerous and as such needs to be installed by someone qualified.
please get someone to call and explain the best solution for you.
Upvote 0
Reply to the thread, titled "New Hot water tank help." which is posted in Plumbing Advice for Any Other Country on Electricians Forums.
