Soldered up a bunch of new pipe work to move a rad and decided to use push fit adapors on the last section where the new pipe joins the existing.
Mainly because it was my first time soldering, the area is quite tight and i struggled to get the existing pipe fully dry in order to make the joint.
Refilled the system to check for leaks and one of the push fits leaks before ive even put the ch on. Its the one up top leaking from the 10mm side
Draining down this leg now so i can remove the offending fitting and replace.
Will double check that the pipe has been properly de burred and use some sort of lube when re fitting.
Any other suggestions when re fitting ?
I always been a bit skeptical as to how reliable these fittings were but thought id try them for the first time.
Probly due to installer error or maybe i just got a dud part but now im thinking i should have just got by trying to solder in an adapter.
