New Radiator Size Issue
View the thread, titled "New Radiator Size Issue" which is posted in UK Plumbers Forums on UK Plumbers Forums.
I have bought new radiators to replace my current ones (around 25 years old). Old radiators were all fitted with TRV's.
I have put the new 15mm compression inserts into the radiator that came with the new valves/TRV's but this then makes the valves too wide to fit onto the existing pipes (by around 20mm). I think the old radiators had the inserts that have to be put in with a radiator valve key.
Do the threaded parts of the radiator that the inserts screw into come up different widths on different brands?
Are you saying that your valves are 3/4” male and the inserts are 1/2” female
https://www.NoLinkingToThis/p/chrome-angled-radiator-valve-drain-off-15mm-x/70408
Ok thanks for all the replies. Looks like getting small radiators with the tail extensions will be the best option. Pipes are in a concrete floor as well which is more difficult as there is no movement on them.
Cheers for the help.
If you own a pipe cutter the one on the right is less likely to leak than the one on the left.
Getting the thread to seal in the radiator can be a bit of a pig if you use PTFE. £20 for a bottle of Loctite 577 even if it’s only for this one job may well save you a lot of hassle in the long term.
If you use a pipe cutter on that chrome it will break the cutting wheel. Better to use a hacksaw (or if you’re brave/mad/have a vice use an angle grinder)
Reply to the thread, titled "New Radiator Size Issue" which is posted in UK Plumbers Forums on Plumbers Forums.
Samwh91,
OffshoreGas,
