M
mozilla19
Hello All,
First Time Poster on this forum and would appreciate some advice on a new S Plan Plus System Im looking to have installed next week.
Im an engineer by profession, however not a heating engineer or plumber, but have picked up a few things here and there and from reading textbooks. Before anyone has a rant, I am going to get a professional heating engineer to install my system based on good, sound engineering practice rather than on my own limited experiences.
Heres what I am looking to achieve:
2 Heating Zones:
Upstairs is 17 KW load across 7 radiators
Downstairs is 17.6 KW Load across 6 radiators
1 DHW Zone comprising of a 170 Litre Megaflow Cylinder... It takes 24KW Boiler Output to get the DHW from 15degC to 60degC in 22 minutes
... A typical S Plan Plus System....
Boiler to be sourced is a 40KW Worcester Bosch CDi Regular Boiler. I can only run it as a 2oo3 system due to the high demands so both heating circuits will have to come on together (if required) at different times to the DHW Circuit.
Based on Rads and pipework that have been installed, I have worked out my required flow rates and pipe resistances (pressure losses which includes plenty of margin) and have decided to go for a Magna1 25-60 pump.
My required head and flow rates are somewhere in the mid range of this Magna1 25-60 variable speed pump (PP2) as opposed to the upper range on a smaller Grundfos Alpha 2L 15-60 or 25-60. I figured the Magna1 pump wont be working as hard, therefore it will last longer.
Calculated index circuit Head came out as 2.5m Head and 1.8m3/hr Flow rate and like I stated previously, does includes lots of margin... I added a 100 percent to the final pipe lengths to account for pressure losses from pipe fittings in order to get my overall system losses. A bit OTT perhaps, but I figured with the possible addition of non-return valves on return circuits, this excess margin I included would account for it... I think one 28mm Check valve has the same resistance as 5 metres of 28mm pipe so the 100% excess I have allowed for in the calculation should be enough.
Calculated expansion vessel size came out to be 28 Litres with 1 bar charge pressure... purchased a 35 Litre just to be on the safe side... dont want the boiler going pop.
Now... Ive attached a 3D drawing that I quickly put together on what I think the system will look like in the small raised timber plinth boiler room I have built and this is where I have some important questions relating to industry practice. There are a couple of things that may not look right which Im hoping you'll point out.
The F in the Return Pipe work is a 28mm Spirotech Magnabooster2 Filter... P is obviously the Pump and is pumping downwards. Advice from Grundfos Technical Department said this was acceptable provided there was an air vent just before it... I believe theres also one inside this Worcester boiler aswell. I contacted Wilo Pumps just to make sure I wasnt being lied to and they said pumping downwards was also acceptable... with an air vent.
Now, hopefully the drawing Ive attached explains itself... Ive tried to incorporate 3 zones using mostly 28mm pipe work and reducing down to 22mm for the Megaflow Cylinder. My big worry was reverse circulation so Ive put in some non return valves on the return sides. Is this acceptable or should I definitely be observing the 3 Tees Rule? I realise the non return valves are adding in a lot of pressure loss, but the variable speed pump will easily eat it up. Please let me know your thoughts...
Ive added a shunt circuit which is the bathroom towel rad (700 Watt)... I figured as its a damp room this should always be heating up regardless of what the system demand is and in the event of a faulty zone valve this circuit will prove to be a life saver. Let me know if you think this is ok... Thought about Auto Bypass Valves but I still think this shunt circuit is a better solution. Ive also heard these Auto Bypass Valves are high failure items aswell... Again let me know your thoughts and why you agree or disagree.
Thats it really... Have a good look and if something dosen't smell right then please do let me know why.
2 Heating Zones:
