New soil stack to toilet connection
View the thread, titled "New soil stack to toilet connection" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi. I'm installing a new soil stack for a new upstairs bathroom. For the toilet, where the 110mm pipe comes through the wall to outside, which pipe fitting do I use? It has to come out and then across to the soil stack, but all the branches and bends are 92.5 or 87.5 degrees but surely it needs to be 90? Also, do I need an access point at this fitting?
Whichever gets you closer to the wall generally, iirc I use 92.5 degrees, it might be that 90 degrees is too tight?
Hi. Thanks. But surely the pipe will come through the wall at an angle?
No, can be as level as you want it, but recommend a slight fall towards the elbow. I think you’re thinking about it differently. The angles refer some to the radius of the bend.
Reply to the thread, titled "New soil stack to toilet connection" which is posted in Boiler Advice Forum on Plumbers Forums.
Adrian_P,
Deleted member 120897,
